charles=fla
- City
- lakeland
- State
- fl
hi from too hot fla..got a may 28 frame, and then the ft end ,weld seam on bottom, ,however wishbone welded to axle,so had to grind wisbone off, and damaged the passenger side fork, where the spring pearch goes through,anyone have a damaged wishbone,they will cut off the fork and sell it to me.think i can cut behind the factory weld, and put back together??..thank you...charles..
