28 Tudor-How do you remove rear window glass?
REByar
I have a 1928 Tudor that needs to have the rear window glass channel's removed. I can roll the window approx. 1/2 way down and it will roll back up. But if I try and roll it all the way down it sounds like the channel is hitting a bolt because when I try to roll it back up it will only go up 1/2 way and you can hear it hitting something. When this happens I have to take the side panel off and then pull a little on the channel and on the middle frame bracket and then push up the glass and it will go past the bolt or whatever it is that the channel is getting stuck on. The channel is rusted appears wider than I have seen in pictures. How do I get the glass out of the channel. It is original glass and channel stuck together with the glass bedding?
Any advice would be greatly appreciated
Randy
