'28 gas tank
oj
Berryville
VA
Price
trade
I have a tank etc from a '28 tudor and i am making a traditional hot rod and will have to cut out the gas tank. It is in great condition, no holes and surface rust on part of the top side only. I believe the sending unit works and has steering column support. The only problem that needs to be fixed is where the radiator rod support bracket was torn from firewall and a repair was done many years ago.
If somebody needs this original piece i will swap it for and aftermaket cowl top.
Thanks, oj
I have a tank that has been cut, top is in very good condition. Was anticipating scraping it, but if you can use it will send it to you. We can work out shipping on your tank after you look mine over.
Ben
