28 ford pickup rear window
ezloader
Wondering the correct way to install the rubber around the window,if you wrap it around the corners bulge and don't think the frame will squish them enough to hide them to the outside,,is the rubber installed as one unit or pieces???
Thanks in advance..DJ: :confused:
Post this in the General Discussion section under Model A, and I'm sure you will get the proper answer. BTW welcome.:)
