They are hard to find. Also need to replace vaves & seats. The Olds heads of the same vintage have three exhaust ports, but are harder to find.
The head is mounted with an adapter between head and block, with a gasket on each side. The adapter mounts to the block, and the head mounts to the adapter (different bolt patterns). The bottom of the head is flat, and the combustion chamber is in the adapter/spacer. The intake ports are on one side and exhaust on the other. The look nice, but I want to make sure it is worth the effort, $$, etc.
