- City
- sunnyside
- State
- WA 98944
- Price
- cheap
This is a list of the AA parts for what ever fits to the 28 to 31 AA I have for sale. 5) frames, Two 157 and three 131, $100. each, $300. if you take all 3). (2 of the 157s have rear springs) 10) 1928 wire wheels, 10) 1928 single mount disc wheels, 5) 29-30 budd wheels(flush), 7) 31 raised budd wheels (all with lock rings), any or all at $50. each, 28-29, 30-31 drums $10.each, same with hubs, at $10. each. 2) pinion housings with good races, $10. per housing. 6) rear backing plates, $10. each, 2) 30 drive shafts, $20. each, (have 29s and 30s) also torque tubes for 29s and 30s, $20.each. 7) rear radius rods, $10. each, 4) rear emergency brake band supports, $10. each, rear emerg/service brake levers, $5. each, 2) front I beam axles, $20. each, 16) brake shoes, $10.each, 2 wish bones, $30. each, Misc baking plate attachments and parts, inquire,3) 28 front springs, $50. ea. 2) front 30-31 springs good used $50. ea. front brake acctuators, $10. each, (tapered ones for 28, $15. ea. 2 Pair 30-31 front spindles VG condition, $100. a pair, 2) pair 28 spindles $100. Strait 30 service brake cross shaft with all levers, $30. 2) sets of front spring u-bolts, with uper and lower clamps, (round type) $30. each set, pair front perch pins with perch nuts, $50. for the pair. 8) complete (not taken apart) 4 speed transmissions all with top loaders, $100. each, Or) will sell separate items, 10) cleaned and engine painted bellhousings, $50. each, 2) early V8 4 speed transmissions both with top loaders, $150. each, one very descent 28-29 AA truck cab, (no wood, cowl, or gas tank, to trade for a descent pair of 29 AA doors. Have other AA parts too numerus to mention. Sell all or possible package deal for all to one person. Cab trade will be separate, trade for doors only. Truck brake wedge, $3. each, Rear end spider 4 ways and 4 good gears, $50. for the set, very good used 28-29 hub bearings, $20. each, very good used 30-31 hub bearings, $20. each. (28-29s are slightly smaller than the 30s. 2 pair of 28-29 short running boards, very strait, $50. for each pair, same for 30-31, also 30-31 short splash aprons, $50. for each pair.Have one 28-29 flatbed frame, all intact but has some straitening to be done on rear cross over with the 4 stake pockets and 6 on the side. $200. Also have one 28 wire wheel overhauled and painted running 131 driving chassis, with cab and sheet metal off frame, has fenders hood and all parts to finish. Has all 4 script hub caps, Asking $5,000. Chassis can be driven onto a trailer. I have driven it 10 miles so far on the back roads. The doors are the worst of it. The flat bed is 3 rear stake pockets. Also have another 28 single disc wheel driving chassis with cab and sheet metal off of frame with all parts. Good driver but not restored. Found it in a barn all together and running. Asking $5,000 for it also. OR $10,000.for all mentioned in a package deal. Everything mentioned in both ads are all of the AAs and AA parts. sangar29@centurylink.net or 253 459 5871 Also have 28 AA AR rear & front end parts
