28 A brakes
Toml
Rebuilding my brakes and all linkage, just removed this clutch and brake pedals, no bushings, not missing never had them it seems. Normal or no. Also how do you remove the clutch, brake pedal shaft PIN, located on the transmission housing? Thank you Tom
The pedals used with the multiple disc clutch were used with a smaller 3/4 diameter pedal shaft and used no bushings. The later pedals were used with a 7/8 shaft and the pedals used bushings.
Sounds like you have multiple disc clutch bell housing. Do your pedals have ribs or smooth faced ? The earliest pedals are smooth and the 2nd generation have ribs. The pedal shaft is smaller. There are no bushings in the pedals with either type.
You probable have what is referred to as "floating brake system" ?
Pictures would help for positive identification.
Ron
