28-29 Sedan/Phaeton Rear Fender Brackets
barnstuf
Cape Cod
MA
Price
$15 ea.
Two used original 1928-29 Sedan and Phaeton rear fender braces. These were on a 1929 and are straight and solid with a bit of surface rust, so will need sandblast and fresh paint. The big boys repro parts catalogs list the repro braces as 1928-31. If you check an original Ford Parts Price List you will see 28-29 brackets differ from 30-31 with different part numbers. I have found thru experience the difference is slight and is in the angle at outer end. My originals are $15 each plus postage. Two available.
Contact Rich at barnstuf@comcast.net
