28-29 sedan delivery door hinges
If we are talking 130-A Deluxe Delivery and not panel delivery.To the best of my knowledge there are no direct replacements. Mine is missing the center hinge, so I am using a Briggs fordor hinge to make a replacement. It is the same style, but the holes will need welded in and redrilled. Also I will have to cut it at an angle to match the contour of the wood in the door jam. I wish I had one to use as a pattern to get it right. Another side note is the door pin head is a different size. I may have enough briggs hinges to make an additional set, but can not gaurantee at this point I would get the center hinge right. Rod
anybody have an idea what ford used on 28-29 sedan delivery for the back door hinges I have the sedan delivery that was in the book Henrys ladies thanks.
