VS81Splicer
I've carefully bent bent back the four cover retaining clips on one of my my tail light drum switches and I'm in the process of making a fixture to push and hold the 7/32" diameter actuating shaft about 1/2" off the switch base rear frame wall. On opposite end of the shaft, I have a claw that should compress the spring so that I can gain access to the 7/32" XRC314 (eXternal Ring Clip) that prevents removal of the actuating shaft. I'm doing this in an attempt to completely disassemble and rebuild a slightly rusted switch assembly by bead blasting the three required (base, cover & actuating rod) components so they can be cadmium plated, as defined in the Joint Judging Standards. Has anybody else tried to cadmium plate their switch? If so, were you successful?
Bob
Bob
