Dennis Pereira Well-known member Aug 10, 2010 #1 I hope this is the correct window frame. Its been hanging on the barn wall for years. Thanks for all the help. Attachments 28-29 standard coupe rear window frame 001.JPG 94.7 KB · Views: 34
Aerocraft Well-known member Aug 10, 2010 #2 That appears to be the correct frame. You can see the gussets in the inside corners of the frame which retain the rubber seal in conjuction with the four corner inserts that you questioned in a prior post. Gar Williams
