Special Coupe Frank
The passenger-side door of my '28 Coupe will not open from the inside.
The inside handle ( "flips-out" from the door ) will operate the latch, but will not pull the bolt far enough to clear the strike in the door pillar.
Is it as simple as removing the trim panel, then removing and bending the remote rod as needed ?
Should the rod be heated first ?
Thanks !
SC Frank
Thanks !
SC Frank
