40cpe
I pulled my distributor and the oil pump drive came out of the pump. If I drop the shaft back into the pump from the distributor hole will it self-guide into the pump? If not, what is the process? Also, one end of the shaft is more pointed than the other. Which end goes to the oil pump?
Thanks, Gene
Thanks, Gene
