If your exhaust system has a heat riser valve you can also remove it or wire it open, assuming you aren't parking the car outside overnight in winter weather then driving it.
When cold, or stuck shut, the valve forces exhaust thru that center passage of the intake manifold. With the valve open or replaced with a spacer, there will be less exhaust going thru that crossover to begin with.
