B BottleRocket Junior Member Sep 4, 2024 #1 When my parking brake lever is vertical, should I be able to push the car in neutral, or does the clutch pedal have to be pressed to the neutral position? Last edited: Sep 4, 2024
J Franklin Well-known member Sep 4, 2024 #2 Vertical on the lever should put the car in the best neutral. Search for adjusting for free neutral for more info.
