agriscience
I worked all weekend trying to bring her back to life from a 7 year slumber.
Checked and adjusted coils, cleaned carb, replaced manifold gaskets, replaced crustuy batery cables, and rinsed out gas tank, changed oil, cleaned plugs, checked compression (50 pounds all), made her run like new.
Toook out for first test drive and had a BLAST!
Not perfect but exciting!
Next day took for another test drive, started off in low all is well and then let up the pedal not moving any faster???Pushed pedal to the floor and slow speed ok!
And then it stoped moving forward and made a noise from under the floorboards/seat?????
The motor still runs but no movement??
Where should I start?
Trans, clutch, rear end, u joint, muffler bearing????
Please advise! New weekend only 3 day away!!
Steve
Steve
