dont take it for granted the mark on the pully and the pointer on the engine are absolutly correct, either one can be off by a 1/4", use the marks to get the engine started, then take the car out for a run, either on the hiway or on a long hard up hiil pull, advance the dist till it pings then back it off till it doesnt ping, seat of the pants timing but it seems the best way, once you find the sweet spot check where it is with a timing lite,then mark it on your crank pully so you will know where to to time it the next time, use a good grade of fuel to reduce pinging
