239 oil pan bolt leak
This thread sealant is great. The other changes you've made should do it. As a last step you could apply this to the threads.
LOCTITE PST 565 Thread Sealant: High Performance, High Viscosity, Rapid Cure, Acrylic Thread Sealant, Anareobic, Replaces Tapes and Pipe Dopes White, 1.69 fl oz Tube (PN: 483629)
About this item
  • RELIABLE THREAD SEALING. Cures rapidly to withstand 10,000 PSI.
  • UNIQUE. Replaces most tapes and pipe dopes and pre-coated parts.
  • MULTI-PURPOSE APPLICATIONS. Stainless steel fittings, Head bolts into through holes, Oil psi- sending units/sensors, Oil and coolant lines
  • SOLUTION. Specifically formulated for metal & Tapered pipe thread fittings.
