S santino2010 Member Mar 18, 2016 #1 Hello I am replacing the head gaskets on my flathead , and I would I would like to know about cleaning the block what sort of sand paper could I use to not scratch the block.. Thanks
petehoovie Well-known member Mar 18, 2016 #2 You should not use sandpaper to prepare the block or heads for new head gaskets. You don't want to get any grit into the cylinder bores....
B Bob C Well-known member Mar 18, 2016 #8 Use a razor blade scraper like this. http://www.lowes.com/ProductDisplay...gId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1 Bob
J Joe Immler Well-known member Mar 18, 2016 #9 I think you will find the scraper posted by Bob C to work very well. I have used it on my engine. No damage.
KGS Well-known member Mar 19, 2016 #11 Use a long handle razor blade scraper, it saves wear and tear on the knuckles and fingers! http://www.nationaltoolwarehouse.co...map=LIS51000&gclid=CMiB5-SgzcsCFdgcgQodagoDnw
