223 valve adjusting question
Rmvr53
hey guys
just bought a rebuilt 223 from a guy that said he couldn't keep the valves adjusted. I pulled the valve cover and I notice there are no cinch/pinch nuts on the adjusters. Are there supposed to be? If so, I think I found his problem!
Bill
These are from a Y-block but IIRC they used the same/similar rocker arms and the photo shows both kinds. The adjusting bolts with a screwdriver slot use a lock nut ('56 & earlier).
The self-locking type are partially hollow with a hex drive ('57 & newer).
I thought at one time there were slightly oversize adjusters available. I remember buying one for a 427, but that was in the early 70's.
here floats a question - can I just take the rocker shaft and rockers off the dead 58 engine and install them on the 64? That eliminates the problem as I would see it. The dead 58 only had 87k on it and this shaft/rockers on the 64 have over 250k
Compare any casting numbers you can find on the rocker arms to see if they're the same.
IIRC in a previous thread you posted it was figured out the engines are the same generation(?) so you've got a good chance the rockers are the same.
I don't know about same generation as the 64 does not use the fuel-miser vacuum system with the carb/distributor, has a larger distributor drive shaft and some other odds and ends. What I believe I posted was in fishing out the part numbers for the rockers, I found in every search the part number for the 58 was the same as the part number for the 64. Now that may be using the 64 rocker as a replacement for the pinch'd screw setup on the 58. I have not been able to find a rocker shaft or pedestal part number to see if those interchange hence the push on the question.
I've never noticed a part number on pedestals or rocker shafts. If they look & measure the same and the oiling holes come up thru the same spots into the pedestals/shafts that would be a good thing. You've got a better than even chance they're interchangeable but I don't know for sure.
Last time I looked, Joblot Automotive in Queens Village, NY still sold the self-locking type adjusters. Just pull out your loose ones and install the new ones. Then re-adjust valve lash.
