TDS
Hi
I finally got my 1935 back on the street but only to run into at new issue
The engine has had a complete rebuild at a machine shop and I therefore took time to rebuild both the carb and the dist. to make sure everything is in perfect condition.
I’m running a Holley 94 carb with 0.050 jets and a 7.5 power valve.
Idle screws are 1, 5 turn out from bottom.
Float is set 1 11/32 and float drop 1 7/16.
Link is set at standard (middle hole)
The dist. got new points, set to 0.014 and the vacuum brake has one turn in.
Timing is set by TDC on piston 1 and advanced with 2 lines on the dist. from TDC clockwise.
It starts immediately and runs perfect at idle.
But when I drive the car it will not take rpm above 40 kmt in second gear and 60 kmt in third without stumble and some backfire trough the exhaust.
Hard to say how many rpm as I don’t have an rpm gauge.
When I depress the pedal, at standstill, it’s the same rpm issue, just a bit more backfire.
I need advice - thanks
