Adam/Mill Valley CA
Can anyone tell me the functional difference between these 2 types of 21 stud cylinder heads for flat top pistons? Both are cast iron, the one with the more tapered combustion chamber (Ford script) looks like the "A1" cylinder head in the '35-36 EFV8 book, the other with the more truncated chamber looks like the later "A2" type. Both are replacement heads date-coded from the 1940's. Is one higher compression than the other, or better in some other way?
Thanks,
Adam
Thanks,
Adam
