21 stud oil pickup
You need a 59a-6615 p/u. They are reproduced. Try Joblot. You also will have to trim the baffle in the pan. Then you are good to go.
What do i nead for a oil pump pickup with a m19 pump in a 1937 engin? Dose any one sell such a thing?
Charlie, It's the same pick up that's used in the later FH truck engines. MAC's carries it as #8RT-6615 and Speedway carries it as their #910-16259. They also carry the screens and screen retainers. As someone else mentioned, you will need to trim the oil pan baffle to allow room for the pick up. I think it is best to just trim out enough of the baffle to allow room for the pick up. This way you will still have some of the sides of the baffle in place to help stop oil from slushing around in the pan. Also, if you try to remove the complete baffle where it is spot welded to the side of the pan, you risk pulling the complete weld off and leaving a hole in the side of the oil pan. Sometimes the pick up tube needs to be carefully adjusted (bent) up or down so that it fits correctly into the bottom of the oil pan. Good luck!
ps.......Aren't you the same Charlie that was at Ol Ron's chili party this past summer? I'm sure I have a picture of your truck that was taken at the party
