21 stud motor babbitt or not?
Brendan
can you tell if a 36 motor has babbitt bearing looking at the main caps?
and are the rod bearings a full floating Bearing?
thanks, Brendan
Brenden, You can easily tell poured babbitt mains from insert mains on a '36 by measuring the center distance between main bearing studs. The poured mains will measure 3" center to center on studs and 3-1/4" on insert bearings on an LB block. It's good to know this because you can quickly check an engine from the lower end w/o the need to remove the main brg caps. The rod bearings would be full floating unless some one has previously changed the crankshaft. JM
Lawrie, That feature is only evident on Canadian blocks; the American blocks don't have that hole. Luckily, all us guys down under got the Canadian stuff and checking for that hole is a quick reliable method of identifying those early blocks. Brian
