The 21 stud engines have bolts, not studs, for the main bearing caps. As seen in the attached links. Anyone know the size of the square head of the bolts?
I assume it is necessary to put a socket on the bolt head to remove the nut.
With insert mains. http://www.vanpeltsales.com/FH_web/FH_images/FH_engine-pics/Flathead_Engine_crankandcam_1937-38.jpg
With babbit mains.http://www.vanpeltsales.com/FH_web/...ics/Flathead_Engine_crankandcam_1933-34V8.jpg
