Al, In order to fit Meyer heads, you will also need to change out just about every headstud. The Meyers are thinner and need shorter studs. Hopefully, you can get them all out without breaking any. If I were you I'd build the engine with domed pistons, and new rings, give it a good valve job while you're there. You will definitely notice an increase in performance running those heads if everything else suits. It is not just a matter of 'chucking on your fancy finned heads'. I run Meyer heads in my 35. I love 'em! Brian
