PeterC
[FONT=arial,helvetica,verdana]Would appreciate your thoughts here - I just pulled from an my original 35 Ford Coupe a 21 stud Ford Flathead motor complete from air cleaner to oil pan that was re-manufactured and installed in the late 70's - has a re-manufactured tag and number on it. It appears to have only a few hundred miles of use before it was properly stored. It runs perfectly and even the clutch and pressure plate are as new (marked re-manufactured as well). It has cast iron heads (not aluminum) with original starter, gen, fan, carb, ignition, exhaust manifolds etc. I may consider selling it as I have a high performance flathead to install and the $ would be helpful to offset cost of the new motor. I am uncertain as to what the value might be. I am familiar with willing seller/will buyer, what the market will bear, etc. Any thoughts on a range of value might be is appreciated. Thanks in advance for your comments.
[/FONT]
[/FONT]
