I don't know how long it will last but if I put Marvel Mystery Oil in the gas it helps a bit. I have been told by another owner that changing the oil more frequently helps. I had the spark plugs changed a couple of years ago and they came out OK except for a couple. I followed the method of first warming up the engine, then tightening the sparkplugs a tiny bit just to break the seal, then shooting the threads with PBblaster and letting it set for about an hour. Then most of the plugs came out easier.
I really want this truck to be my last one. I hate to get into a newer truck with LCD screens that have all the directions for every function, that you can't read or set while driving. And the buzzers, dingers, chimes that are always going off. And the traction control that makes it impossible to drive in snow if you learned how to really drive in it years ago. I'm 84. I want to enjoy driving with ME in control of the truck. And yes, it is only two wheel drive, no problem.
Has anybody here done a Ford 5.4-to-Cummins diesel conversion? I hear that swap is a real problem-solver that will work for years.
