Cost for a good touring car is less with a pinto
Just went on a run from Fresno,Ca to Mariposa, Ca Models A with converted engines and none had a problems going up the grades.
With all due respect, could you elaborate on this thought?
My thoughts are that a core Pinto engine ain't cheap anymore due to the Hobby stock 4 cylinder class at the dirt track using up all the cores. Then someone needs to factor in the $$ of either purchasing a kit (now obsolete) or fabricating the adapters, brackets, and items necessary for the install, plus do the installation.
Time is money too.
Now, lets compare apples-to-apples again with the engine itself. The machine work for boring, honing, and decking are nearly the same since both are 4 cylinders. Buying a good quality camshaft for either engine should set you back about the same with either engine. To buy a well constructed bullet-proof 2000 cc engine from a reputable builder will set you back over $4k if it has good parts in it. The same applies for a Model-A engine.
Granted we could banter back and forth all afternoon nitpicking which item is cheaper but like was mentioned above, for the extra amount of work/expense installing the Pinto engine vs. building a nice Model-A engine, I think most will agree the Model-A engine will have the upper hand. This also applies during re-sale time.
I always thought I'd like a A with pinto engine or the chevy 2 engine (4 cylinder) with chevy engine you can use t5 ****** make a great driver out of it .
Sure, then you do what to the driveline to adapt the T-5? Now we are talking open driveline conversion (--or engineer a closed one) which affects brakes, etc. etc. Many can make a great argument that for many years they were
great driver's without the need of a Pinto engine or a T-5 transmission. Sometimes re-inventing the wheel is not the most prudent thing to do IMO. Your car though so do as you wish....
