RobR'35
I've totally rebuild the complete drive line on my roadster. It has a vibration starts at 25 mph and is worse at 30 mph. as speed increases it diminishes until I get to 55 mph and at 60 it's worse and remains to 65 mph. Ive not driven it faster because the vibration is terrible. Tires balanced. Wheels checked (Kelsey hayes) with a dial indicator for out of round max was .068 on one the rest were in the .040 or less range and the faces were .048 at the worse.
Transmission, original to the car rebuilt using Macs book to exact specs. All new bearings. Wherever it needed parts and wherever I could aquire nos it got it.
Rear axle is a '46-'48 with the columbia. All new bearings,Timken, Bower or Ford script, ring and pinion nos. All spec's and pre loads checked and rechecked. All the mods to update the Columbia had been done to the axle before I bought it, I checked and spoke with a few Columbia guys. John Connelly being one.
Driveshaft hollow type, modified with 6 spine to mesh with the pinion. These things done by a reputable drive shaft shop and set straight and true. I had the torque tube checked for straight and to make sure the end that bolts to the axle center was 90° to axis. Nos bearing and race. Bearing area on the shaft wear area was only .0015 wore.
U joint was an old used Ford one. I checked it the best I could. Used a feeler guage between the trunion bearings and trunion pins. .002 max I could fit. Spline fit was great!
I do notice with all of the u joints I have and the one installed that they all wiggle laterally. Slide from trunion to trunion across from each other all 4 points by about 3/32". When all installed and coupled to tha trasmission it was packed and grease added after it was coupled. Corn head grease.
I've got about 600 miles only on it and don't know what to think.
U guys have any ideas, experiences to help me out?
