Hello, I am trying to adjust my two tooth steering box. I have installed new bearings for the worm gear(using the original worm), new sector shaft bushings, and a new sector shaft. My problem is that if I adjust the eccentric so that I can get the full left to right(about 3 turns), there is no play at the center, but going to each end, there is a fair amount of play... I talked to a friend who has had Model A's for over 60 years, and he said it should have a bit of play in the center, and tight on the ends... I think that the sector shaft that I got is probably the culprit. Any ideas? Also, moving the eccentric rivet left or right did not help. Thank you, Dave
