I am running a 51 truck engine in my 1949 ford custom club coupe with 2 Strom. chromeplated 97s on top of an Edmunds custom polished aluminum intake manifold. 12 volt system with a mallory electronic distributor. Car ran great until my 10 yr. old electric fuel pump died, or so I thought. Installed a Carter 2 to 4 lb. elec. pump and a 1 to 4 lb. Holley fuel regulator from Mac's. With engine running and the reg. set screw turned all the way in (clockwise ) the guage only reads 2 lbs, even when revving. I assume the pump is not putting out 4 lbs. as advertised. I then pulled the plugs and cleaned them, they were black. With the engine running I set the reg. to 1 1/2 lbs. and took a ride. same result, ran good up to 55 mph , started to fumble and I backed down. When I back down she still fumbles and will not smooth out and I head home. I pull the plugs and they are black again. Acts like its starving but maybe its flooding. The coil is good, could it be electrical? Also when I pull the vacuum line from the intake mani. which operates my Vintage air heater/def., the engine revs up. I have run with this line on and off but engine still runs the same. I'm puzzled. I hope that makes my problem clearer. Thanks again! rozroost
