leo
So I pull the rear wheel on the passenger side of my 1930 coupe and when I try to put it back I find 2 hub bolts can no longer be tightened and I know it's not the lug nuts because I used those two on another wheel and they snugged up nicely. Never had this problem happen before. Is the only solution to pull the hub and have the 2 offending bolts pressed out and replaced? What also puzzles me is that the 2 hub bolts do not looked stripped.
