Before I retired, I added onto my garage, and I installed a Mohawk 10,000 lb. twin post lift. It might be larger than 10K, I've had stroke? Just the hoist alone was over $10,000.00 (not installed). It required a 12" thick slab with rebar. I was a phone company mechanic, and we had inground twin post lifts up to 36,000 lbs. but we had one Mohawk above ground twin post hoist. I was so impressed with it I bought one, but it was stupid expensive. It's made to last forever. The uprights are made from 1/4" inch steel forklift masts. Every part of it is made in the USA. I can lift small cars up to dually pickups on it. I can lift by the frame, but I also bought the adaptors to be able to lift by the tires in case I don't want to scratch up the frame.
One year they replaced one of the inground hoists at work that was over 30-years old. I took the front rack head with its 4X4 adapters home. I made a tool to slide rearends in and out from under cars. I can lift the vehicle on the rack and then roll the front or rearend right out from under it. Iv'e had back surgery so no more lifting heavy stuff.
