2 Model A Motors and Transmission
jayg30
Bristol
CT
I have 2 Model A motors for sale.
The first is an intact motor and transmission. This motor has not been disassembled and includes the manifolds, water outlets, throttle linkage, starter, bellhousing and transmission. No carb, water pump or generator. It is a 1929 serial number A2045414. $250
The second is more of a short block. It has been disassembled to start a rebuild. (not by me) It has new pistons, side cover and return pipe and oil pan. A cracked head is on it but can be removed to view the cylinders. I don't know what if any machine work was done. This is also a 1929 serial number A2718756 with a factory double stamp of A2718764 $100
I May be interestd in that first complete engine you mention in your post. Can you email me a pic. I am in ct and not far from you. Thanks latecomer
