2 different wire wheels
harvest
i came across a set of wire wheels that i know don't match. im curious to what year model T they came on. the 1st rim measures 20.25" diameter x 4"wide and the 2nd rim measures 22" X 4" wide. thank you for your help identifying.
The first one is for a '30-'31 Ford, the other might be for a T or maybe not depending on closer examination.
j franklin, thank you for identity on the 30/31 wire wheel. Did they make a taller wire wheel for 26/27 T's?
I think that skinny wheel is for a model T but i can't get a good enough look at the center to see if it's for a T or an A.
The 2ed one: 1928-29 21" Model A. The hub section is too large for T. I suggest asking on the Model A forum. The 21" wheel might be AR (early). The early wheels may not have had the brace ribs between each stud hole area. The 1st one is for sure 19" 1930-31 Model A. This is a poor photo but it will show the hub size of the T 21" wires;
