gdmn852
Hello I have always used the repro aluminum 2 blade fan , one thing to be cautious about is the clearance between pump and inner pulley area as being cast they are thicker than originally, some grinding of pump may be necessary. Was a previous post on Ford Barn where someone mounted the 2 blade and had problems with clearance. At higher speeds the fan does little, more modern cars usually had a clutch allowing the fan to freewheel. I hope this helps.
