My post in #31 only mentioned the one change that came with the 1CM cam for the Mercury cars since I was in too big a hurry to add that the automatic transmission was also introduced with the 1951 around February of that production year. The valve pockets started losing the hardened seats in the intakes. The actual change in the cam was likely for better low end torque. The Ford-O-Matic and Merc-O-Matic transmissions were designed to start out in 2nd gear. The 1st gear selection was for starting out with high cabin loads or with a trailer and could only be selected manually by the operator. They needed as much low end torque as they could get with a stock flathead.
The rotators didn't need a change in the cam to work but they changed valve springs and went with the cone cup type hold down for the retainers and shorter valve springs. They also changed the tappet clearances for this and the valves are about .020" shorter. The change in clearance was for the new valves only. I own two early 1951 Mercs and they have conventional valves and the 8CM cam so I use the 1949 thru 50 clearances on them. This isn't mentioned in the 1949 thru 51 Lincoln Mercury overhaul manual. Ford used the 8BA-6250-B cam for the change over till the EAB cam came out. The blocks reflected the 1BA change. This was all for the Automatic transmission changes plus the valve changes.
