1991 Ford Bronco Fuel Pump?
leo
I need to pull the sending unit from the tank to see if the unit or float are not working and while I'm there I thought it would be good to change the 23 year old fuel pump. Well, Motorcraft sending unit and fuel pump $300, Airtex fuel pump $65, Autobest fuel pump $48, APE fuel pump $38. Who are these companies? Can someone out there tell me what they have used and are happy with. Thanks.
The Motorcraft comes with the flange that mounts it in the tank. You'll need to transfer the sending unit. The other pumps you mentioned have to be mounted on the original flange and the pump wiring spliced in.
Airtex has been around a long time and is usually known for quality,if it's cheap probably it's offshore made and you take your chances.
