mikecbrown
New member
- City
- Traverse City
- State
- Michigan
- Price
- 14,000
FOR SALE $14,000
1981 SHAY MODEL A
1929 MODEL A RUMBLE SEAT ROADSTER CONVERTIBLE REPLICA
Only 6226 miles
Factory built (around 2,000 produced) fiberglass 1929 Model A replica, convertible with rumble seat. Produced in Battle Creek, Michigan from 1979 to 1981. Ford Pinto 2.3 Liter 4 cylinder, 4 speed transmission and rear axle. Mustang II front end, frame and body by Shay. Sold through Ford dealerships. Antique looks with modern drive train steering and disk brakes, capable of highway speeds.
Go to http://www.shayhistory.com/ to learn more about the car.
NEW timing belt and tensioner, alternator belt, radiator hoses, heater hoses, antifreeze, oil and filter, air cleaner, header and complete exhaust, fuel filter, brake fluid, transmission oil and rear differential oil.
SERVICED Engine desmogged (pollution control equipment removed), brakes flushed, cooling system flushed, all fluids changed, carburetor modified, timing re-set, front wheel bearings re-packed, ball joint zerk fittings installed, custom steering column brace / bearing installed, seat riser installed, transmission to bell housing bolts re-torqued (required R&R of transmission and bell housing) new shifter bushing installed and linkage lubed.
TIRES AND WHEELS 2 complete sets. Original 18 inch spoked wheels with newer bias ply tires for show. No weather checking or cracks, Balance Beads installed. Modern 15 inch aluminum wheels with 60 series radials for drive-ability and performance.
Top and side curtains included
Car is better than new, ready to be driven anywhere
No Text Please - home phone 231 941-5076
1981 SHAY MODEL A
Only 6226 miles
