1970's Nostalgic Model T Hot Rod
fordtrk56
San Diego
Ca
Price
in ad
This is a true barn find..ALL NEW 1970's time capsule nostalgic 1927 Ford Model T Hot Rod mounted on Model A frame...All STEEL and No Rust..Runs perfect..Starts up first time,every time..Fresh rebuilt 292 Y block engine,original T Bird aluminum valve covers,Holley 4bbl,K&N air filter,coated headers,3spd manual trans with hydraulic clutch..ALL NEW...spark plug wires,exhaust system,entire brake system which includes wheel cylinders,master cylinder,rubber hoses,brake hardware,steel brake lines and fittings.Completely new wiring with circuit breakers.New pressurized Brass radiator.New fuel tank and electric fuel pump.New Goodyear tires.New front 2 piece windshield.New 12V wiper motor and wiper arm.New volt regulator,starter relay,battery cables,horn relay.New Old school ET 5 spoke Mag wheels.New wood steering wheel..CHROME front axle,tie rod,front/rear hair pins,front/rear backing plates,2 piece windshield frame,rear end cover,head lite rings..12V head light conversion.Corvair steering box.Has turn signals and park lights wired into cowl lights.Stewart Warner gauges.Dash reading light.Complete top bowassembly..Rear fenders have been widened with steel inserts..Ford script running boards and license plate light..Current California Non Op Title in hand...This car could be driven home..A really cool Hot Rod..Needs your paint color and upholstery added..This car shows of good craftsmanship and pride of assembly... price $15000
