1969 Ford 1/2 ton pick up 50's Custom
RetSFC
New member
Brockport
New York
Price
15,000.00
1969 Ford 1/2 ton truck, totally custom. 4" chopped top, rear cab window changed to Ford Oval shape, angled quad headlights, handmade stainless steel tube grille, rolled pans front and rear, Front and rear frenched license plate, all body seams filled, painted blue/green pearl with violet pearl ghost flames, full tinted glass, power windows, dummy spot lights, shaved rain gutters, 85 Honda prelude inner & outer door handles & latches, frenched power antennae in right rear of cab, Frenched 39 Ford tailights, Dummy lakes pipes, Tonnau Cover, smoothed tailgate, gas tank moved to bed with side fill door, Keyless entry, security system, tilt column, high back reclining bucket seats, P/S, power disc brakes (front), 460 c.i., Lunati cam, Edlebrock intake, 750 Edlebrock carb, headers, 2 1/2" exhaust with 18" glasspacks, C 6, 9" with 28 spline axles, 3.25:1 gears, Posi. New upholstery,
New Heater core, New carpet, New Headliner, New front tires
This truck has been and still is registered & insured year round. It runs and drives great, and has always been very reliable. It drives exceptionally well for just cruising and is very fast when you want to play around. I am the 2nd owner, buying the truck in Southern California prior to moving to New York in 85. All the custom work was done in 2006.
ALL body modifications & customizing was done with METAL, NOT bondo. I have pictures of the build.
Due to health reasons I must sell this truck. There is some work that needs to be done to finish it that I cannot do. The NEW headliner needs to be installed (cardboard with chrome trim), NEW carpet needs installed, the ghost flames need to be sanded with 2000 and polished out. There is a small crack in the windshield behind the right (passenger) dummy spot light. The left door glass is cracked (cracked before I even drove the truck). The cracks do not prevent it from passing New York's annual vehicle inspection.
I have a written appraisal from the International Vehicle Appraisers Network dated December 1, 2008 showing this truck as having a value of $17,500.00. this was before I detailed under the hood, and added the ghost flames.
Please contact me with any questions you may have, or you would like more pictures. Thank you for looking
