1969 emergency flasher solved!
alarot
When in doubt switch the switch! Thanks for ebay idea. Bought used one(hard to find) and it made all lights work+eliminated battery drain. Easy solution to a troubling issue given the nature of 40 year old wiring harness.
I'm working on a 69 Torino. When I got it, none of the interior lights worked. The fuse box had 3 bad fuse holders. I added an extra fuse box with 4 of the new style plug in fuses and wired it off of the hot side of the old box. Right away the Flashers worked and the dome light worked.
