I am trying to set the timing with a timing light
I have a Pertronics electric advance module in the distributor and no vacuum connection.
The 'flywheel' has a white line on it that seems to correspond to the pointer on the engine
Is that mark TD or a stock setting of ??? 6 degrees or 12 - 14 degrees?
I have a Pertronics electric advance in the distributor and no vacuum connection.
Recommended static advance setting?
I wish I had a numbered taped on the 'flywheel' - then i could check for what really matters - the 36 degrees at full advance
