I'm working on a 1966 Mustang A code 4 speed car. I took off my driveshaft to change ujoints and the joint on the rearend side gave me issues. The New U joint was just slightly too wide to fit. I compared the new U joint to the old U joint and the new one its just slightly wider. Like a 1/16" of a Inch. The new U joint Part number is #498. I tried napa, O' Reillys, and a local parts store, whom all gave me different brand U joints, all with the same part number, but they all were wider than the old U joint. So I took the driveshaft to a place that specializes in driveshafts and they insist that my driveshaft end that holds the U joint has been bent in and that is why the new replacement U joints won't fit (even though the new u joint is wider then my old one) and they want to change the end on my driveshaft, however they "can't get" the original style end for my driveshaft so they want to put something else on. So I have a few questions
First has anybody run into this before ?
Does anybody make the correct U joint ?
Where can I get the correct replacement end for my driveshaft ?
