1966 Ford mustang
Dennis Pereira
Is there a trick to removing this chrome piece? so I can sand this area.
Has to come off from the inside. There's about 5 nuts that hold it on, 1 on each of those fingers and a couple on the large vertical piece.
Take off the inner trim panel and then worm your way up behind the window regulator with either a ratching box wrench, a 1/4" drive ratchet, or just a plain wrench. I think the size of the nut is either 3/8 or 7/16.
Some of the reproductions have smaller studs on them and get installed with barrel nuts (spring loaded inserts) like the running pony and 289 emblem.
