1966 f100 short bed
mike07
kenmore
new york
Price
15900
1966 f100 short bed, fresh professionaly rebuilt 390 engine, edelbrock cam and intake manifold,holley carb, obx stainless headers, flowmaster mufflers,
rebuilt c6 trans with acc converter, 3000 miles on all mechanicals
9" rear end
suspension,dropped djm beams in front, new king pins,new coil springs,
djm rear lowering spring mounts and shackles
power disc brakes up front, drum rear, new a/m master cylinder and booster
power steering with column from 1979 f100
a/c with vintage air componets,new compressor, hoses,condersor, and in the dash unit
custom interior with power windows,custom dash with dolfin instruments, after market fuse block and wiring harness,new carpeting,custom dash pad,door panels,seat and headliner,new seat belts
body: all body seams welded and filled,t-bird hood scoop, vents on cowl filled,rolled pans front and rear, smoothed tail gate with inside latches, grille rechromed with custom headlights and new headlight doorsnew door handles,locks, wiper ars and blades,new weathstripping and door seals,new windshield,new side trim
custom paint:dupont hot hues plum crazy/champagne fizz base/clear coat
mustang fuel tank under bed with filler in bed
third brake light molded in cab
bedliner sprayed on floor of bed
new tires
please note price change $15900
am/fm radio with cd player, hidden antenna under dash, speakrs behind seat
upper color is plum crazy, most pics have a blue tint, color is purple
interior is 2 shades of grey,doesn't show very good in these pics
Like your dash! Also like the fact you have the turn signels in the head lights, super clean look!
Thanks, I didnt like the lights above the grille. I used the nose piece from a 64 so I could smooth out the front end
