1964 f-100 power steering
ron
i want to put power steering on my 64 ford f-100 does anybody know of a supplier or a swap from another that would work.
My 52 f1 now has a Toyota ps box from 1981 to 1984 4x4 push pull.Mid fifty has a kit that you can use.It works well ,this fix has been around for over 20 years.
You can also go with GM box, via cross steer, with a specialty right side tie rod end avaiable from Speedway, among others. If you are industrious, you can use the control valve and ram from a early Mustang or Grenada, using your original box. good luck!
