1963 ford thunderbird convert
the pump should be located behind the back seat may have access through trunk should have a plug to fill I'm sure others will have more information
The pump is on the rear axle hump in the trunk. There should be a flat headed slotted screw. That is the fill hole. There is most likely a leak. The solenoids are prone as are the pistons. Both are available from various suppliers. (as remembered from my long gone 62)
I have a 61 Thunderbird Convertible. I got my fan clutch from Thunderbird headquarters. It is short and fits perfect. Make sure you have the correct fan for use with the clutch.
I just moved to Houston and have an extra fan if you need it.
Rich
