Unless the gasket is pliable and soft, I replace them when I change a windshield or back glass. I cut them out with a utility knife from the inside of the car. The one in my '59 was badly cracked, so I didn't have to be careful with it.
Remove all the inside trim and mask off anything you don't want sliced up. Once you see the metal lip all the way around, it should push out easily.
